TwinTurbo.NET: Nissan 300ZX forum - 2001 nissan sentra 1.8l manual gxe
Subject 2001 nissan sentra 1.8l manual gxe
Posted by inf on March 05, 2013 at 6:27 PM
  This message has been viewed 315 times.
Message I'm trying to diagnose a no start problem (does crank tho) on this vehicle. Cylinders 2 and 3 are not sparking. The coil packs are fine as I've swapped them with cylinder 4 and ran an inline spark tester to verify no spark. The plugs have fuel on them so I've ruled out fuel...in addition to a fuel pressure test (40psi). I've test the connectors and receive 12 volts to all of the pins on both cylinders...same as cylinder 4. I've replaced the plugs and crank position sensor. Does anyone have any suggestions? I'm beginning to suspect a faulty ecu.
